Hey Jay,
In the first chapter of your book you mentioned both useradd and adduser for creating users.
Later in that chapter you explained adding a user to a group with usermod -aG.
I was wondering if you are aware of the adduser <user> <group> variant of adduser?
According to the documentation (see last paragraph under Description), this command also adds an existing user to an existing group, much identical to usermod -aG.
Perhaps it’s a good idea to mention this variant as well in your next book revision? I personally find the adduser <user> <group> variant a bit more pleasing to use because it prints feedback to the terminal (whereas usermod -aG prints nothing at all) and it’s very easy to execute after adduser <user> by just recalling that command and appending the group.
Let me know your thoughts, were you aware of this approach before?
