Tips and tricks for a new homelab
I’m using CentOS and Fedora. I want to run security cameras, media and use it for storage for my home and recording studio to share files from anywhere. My question is what list of software would I need to accomplish this setup. something simple and easy for a new Linux user. I will be building my server with a gang of storage and raid config. Since I’m new to this home lab a lot of thing go right over my head so I will have to do my homework and learn everything you guys list for me. I need to get me a Linux mentor lol.
Should I run VM on my server or just use the physical machine?
First, welcome aboard @tayray
I’d recommend searching for open-source applications within the area of applications you need.
For storage, I started with OMV and then later migrated to TrueNAS. I think OMV was easier to learn and get started with. TrueNAS, IMHO, is enterprise-grade.
I don’t have any security cameras, so I can’t be of much help there, but there open-source apps out there. I hear Frigate mentioned from time to time.
For recording, I use Ardour with a Scarlett 2i2. I have a pair of KRK v8’s connected directly to the Scarlett. This works well for me, but my recording needs are very basic. I’m only recording myself playing along with songs as a method to improve my playing technique.
You can use VMs to host your apps. I used to do that, but I have moved all of my apps into Docker (compose) and I don’t have any VMs running anymore (and I couldn’t be happier). Containers have a definite learning curve, but IMHO it is definitely worth it. For me, managing containers (backups, updates, and moving containers between servers) is soooo much easier than VMs.
I did run libvirt/KVM for several years, though, and managed the VMs with cockpit & VirtualMachineManager (remote access) and it worked for me.
I build a server from spare parts back around 2017. It was a 6-core AMD with 32GBs for RAM. I thought that would be enough to run a couple of VMs. I quickly found out that it was over-kill. At one point, I think I had 12 VMs running and the server spent almost all of it’s time idling, meaning that it was using very few resources (CPU/memory).
I’m currently hosting 18 containers on a rpi-4 with 8GB and it is using 12-25% CPU and less than 3 of the 8GBs of memory. I am slowly migrating to minipc’s with 2.5gb NICs as I slowly upgrade my network.
Good luck on your search for applications, and, welcome to the open-source community.
Great information, you have most definitely open my eyes to some new ideals. I will have to do my home work on the things you recommended. Thanks for the help and information.
IMHO, it’s all about the journey, not the destination.
Hey, Should I try and run everything off one server or have multiple server for every task?
That depends on what you want to run and how much resources it needs compared to how much resources you provide each VM.
Start with one and monitor resource usage, then go from there.
Ok, so I’ll start with the NAS system first.
I’m not sure of the mother board or cpu yet but I will at the minimal be running 8 2TB 2.5 drives and probably about 32G RAM.
That sounds like a good place to start.
