Hello,
I rebooted after noticing I could no longer use lutris because vulkan issues. I had just updated system so thought a reboot might be first order then got stuck at loading screen.
TTY will only stay on the screen if I hold crl + alt f1,f2 etc (can’t enter any commands)
Chrooted in on liveISO and did the following, and got the following errors.
mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.49-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [encrypt]
-> Running build hook: [openswap]
-> Running build hook: [resume]
-> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
[manjaro-gnome /]# pacman -Syu
:: Synchronizing package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade...
resolving dependencies...
looking for conflicting packages...
Packages (2) libpamac-11.6.2+3+g76d2753-1 libpamac-flatpak-plugin-11.6.2+3+g76d2753-1
Total Download Size: 0.88 MiB
Total Installed Size: 3.77 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
libpamac-flatpak-plugin-11.6.2+3+g76d2753-1-x86_64 31.4 KiB 177 KiB/s 00:00 [#############################################################################] 100%
libpamac-11.6.2+3+g76d2753-1-x86_64 872.8 KiB 2.15 MiB/s 00:00 [#############################################################################] 100%
Total (2/2) 904.2 KiB 1350 KiB/s 00:01 [#############################################################################] 100%
(2/2) checking keys in keyring [#############################################################################] 100%
(2/2) checking package integrity [#############################################################################] 100%
(2/2) loading package files [#############################################################################] 100%
(2/2) checking for file conflicts [#############################################################################] 100%
(2/2) checking available disk space [#############################################################################] 100%
:: Running pre-transaction hooks...
(1/1) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
** (process:82): CRITICAL **: 09:26:29.763: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:82): CRITICAL **: 09:26:29.764: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:82): CRITICAL **: 09:26:29.766: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:82): CRITICAL **: 09:26:29.766: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
E: Selected snapshot device is not a system disk
E: Select BTRFS system disk with root subvolume (@)
** (process:122): CRITICAL **: 09:26:29.864: gee_abstract_collection_get_size: assertion 'self != NULL' failed
Generating grub configuration file ...
Found theme: /usr/share/grub/themes/manjaro/theme.txt
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-08-29 15:47:08 | timeshift-btrfs/snapshots/2023-08-29_15-47-08/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-08-29 15:42:51 | timeshift-btrfs/snapshots/2023-08-29_15-42-50/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-08-26 13:20:52 | timeshift-btrfs/snapshots/2023-08-26_13-20-52/@ | ondemand | N/A |
Found snapshot: 2023-08-26 08:07:47 | timeshift-btrfs/snapshots/2023-08-26_08-07-47/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 4 snapshot(s)
Unmount /tmp/grub-btrfs.ZfPXo9jGXf .. Success
Found memtest86+ image: /boot/memtest86+/memtest.bin
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
:: Processing package changes...
(1/2) upgrading libpamac [#############################################################################] 100%
(2/2) upgrading libpamac-flatpak-plugin [#############################################################################] 100%
:: Running post-transaction hooks...
(1/4) Reloading system manager configuration...
Skipped: Running in chroot.
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating the MIME type database...
(4/4) Reloading system bus configuration...
pacman -S linux
warning: linux61-6.1.49-1 is up to date -- reinstalling
Packages (1) linux61-6.1.49-1
Total Download Size: 138.68 MiB
Total Installed Size: 143.17 MiB
linux61-6.1.49-1-x86_64 138.7 MiB 21.1 MiB/s 00:07 [#############################################################################] 100%
(1/1) checking keys in keyring [#############################################################################] 100%
(1/1) checking package integrity [#############################################################################] 100%
(1/1) loading package files [#############################################################################] 100%
(1/1) checking for file conflicts [#############################################################################] 100%
(1/1) checking available disk space [#############################################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
** (process:8099): CRITICAL **: 09:32:47.113: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:8099): CRITICAL **: 09:32:47.113: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:8099): CRITICAL **: 09:32:47.115: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:8099): CRITICAL **: 09:32:47.115: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:8139): CRITICAL **: 09:32:47.206: gee_abstract_collection_get_size: assertion 'self != NULL' failed
Found 4 snapshot(s)
Unmount /tmp/grub-btrfs.hraj04tJK6 .. Success
done
(2/2) Remove upgraded DKMS modules
(1/1) reinstalling linux61 [#############################################################################] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Updating module dependencies...
(3/6) Install DKMS modules
==> ERROR: Missing 6.1.49-1-MANJARO kernel headers for module nvidia/535.104.05.
(4/6) Updating linux initcpios...
(5/6) Updating Kernel initcpios for Nvidia-DRM...
(6/6) Updating Grub-Bootmenu
Found 4 snapshot(s)
Unmount /tmp/grub-btrfs.hdUiTdbhca .. Success
done
