Hi!
I just installed home assistant on a raspberry pi and want to set it behind reverse proxy. So I installed nginx on my fedora server (running in a proxmox vm) and this is the config file:
server {
listen 80;
server_name dom.jeansibelius.net;
location / {
proxy_pass http://something.something.something.100:8123/;
I have set up port forwarding on my router (80 => nginx_server:80, 443 => nginx_server:443).
Also I have set up subdomain (dom.jeansibelius.net) to point to my public ip address.
So when I go to http://dom.jeansibelius.net/ I should see my home assistant, but I do not…
I only see “Secure site not available” and after accepting I see “connection was reset”.
Nothing in /var/log/nginx/access.log and in /var/log/nginx/error.log.
Can you guys help me?
Kazimierz Krauze
You will need to configure your DNS to point there as well. Not sure what you are using for DNS. Is it safe to assume you are using ISP defaults?
*.jeansibelius.net points to my public IP, I’m using Cloudflare.
Does your local DNS have a record for that? What does dom.jeansibelius.net point to locally? It should point to your NGINX server and nginx will direct from there assuming ports are configured correctly.
Thank you for your reply, but I’ve given up with a reverse proxy.
I’ve been using nginx reverse proxy manager in docker with pihole (in docker as well) for several years and it works good for me.
I do not have an internet facing domain, so I use home.arpa as my internal domain. I created a DNS record to point that domain to npm, and, I created DNS records (alias’s really since they all share the same IP) for each application name.
I’m currently hosting 18 containers on a RPI-4 and I’m averaging about 18% CPU utilization and about 2.5gb of RAM (out of 8GB). It’s all for a one-person homelab, but it works great for me.
