Hi, Everyone.
I am trying to learn Linux and watched both Jay and Andrew Mallet tutorial on how to configure Public Authentication but I am hitting a brick wall with 2 problems.
1. Problem is, although I was successfully copied over the Public Key to target server I am still getting prompt for a password instead of passphrase
2. If set the "PasswordAuthentication" to no I get hit in "sshd_config" I get an error of Permission denied (publickey,gssapi-keyex,gssapi-with-mic)
Here is the configuration from sshd_config file:
#Port 22
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
HostKey /etc/ssh/ssh_host_ed25519_key#Ciphers and keying
#RekeyLimit default none#Logging
#SyslogFacility AUTH
SyslogFacility AUTHPRIV
#LogLevel INFO#Authentication:
#LoginGraceTime 2m
PermitRootLogin no
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10PubkeyAuthentication yes
#The default is to check both .ssh/authorized_keys and .ssh/authorized_keys2
#but this is overridden so installations will only check .ssh/authorized_keys
AuthorizedKeysFile ~/.ssh/authorized_keys#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none
#AuthorizedKeysCommandUser nobody#For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
#Change to yes if you don’t trust ~/.ssh/known_hosts for
#IgnoreUserKnownHosts no
#Don’t read the user’s ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes#To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes
#PermitEmptyPasswords no
PasswordAuthentication yes#Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
ChallengeResponseAuthentication no#Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
#KerberosUseKuserok yes#GSSAPI options
GSSAPIAuthentication yes
GSSAPICleanupCredentials no
#GSSAPIStrictAcceptorCheck yes
#GSSAPIKeyExchange no
#GSSAPIEnablek5users no#Set this to ‘yes’ to enable PAM authentication, account processing,
#and session processing. If this is enabled, PAM authentication will
#be allowed through the ChallengeResponseAuthentication and
#PasswordAuthentication. Depending on your PAM configuration,
#PAM authentication via ChallengeResponseAuthentication may bypass
#the setting of “PermitRootLogin without-password”.
#If you just want the PAM account and session checks to run without
#PAM authentication, then enable this but set PasswordAuthentication
#and ChallengeResponseAuthentication to ‘no’.
#WARNING: ‘UsePAM no’ is not supported in Red Hat Enterprise Linux and may cause several
#problems.
UsePAM yes#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PermitTTY yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation sandbox
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#ShowPatchLevel no
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
#VersionAddendum none#no default banner path
#Banner none#Accept locale-related environment variables
AcceptEnv LANG LC_CTYPE LC_NUMERIC LC_TIME LC_COLLATE LC_MONETARY LC_MESSAGES
AcceptEnv LC_PAPER LC_NAME LC_ADDRESS LC_TELEPHONE LC_MEASUREMENT
AcceptEnv LC_IDENTIFICATION LC_ALL LANGUAGE
AcceptEnv XMODIFIERS#override default of no subsystems
Subsystem sftp /usr/libexec/openssh/sftp-server#Example of overriding settings on a per-user basis
#Match User anoncvs
#X11Forwarding no
#AllowTcpForwarding no
#PermitTTY no
#ForceCommand cvs server
Hope you can point out what I have overlooked, if you need more info please let me know and this is a vm for studying so I can provide everything in this VM.
I’ve always hated letting something go until I’ve figured out the root cause, and now that I’m retired and have time to burn, I can afford to do so…
