Enjoy Jay’s videos and started dabbling with Proxmox. When I got to Lesson 13, I tried setting up a separate bridge for VMs. Not having a second router, I got a Linksys MX4300(LN1301) to hook up through a USB-C adapter. I was a able connect to the setup (after a hard reset) and network cable to 192.168.1.1.
192.168.1.1 is main network running off an ORBI, So I set the LN1301 to 192.168.2.1. Linksy only allowed 192.168.xx.xx addresses. I set up VMBR1 to run the VMs and cable connected to the ORBI to use as the gateway.
I couldn’t find a way to disable the LN1301 WiFi so it’s possible that conflicts could be the result. I don’t have a switch and I’m not running PFSense. I can see the LN1301 WiFI is available with nmcli device wiifi.
Without firewall changes, I assume local traffic on 192.168.2.XX is isolated from the main network (192.168.1.xxx), including the ProxMox CM(?).
FWIW, I’m running ProxMox on a 16G Beelink i5.
