I would like to seup a proxmox server that will act like a router using pfSense VM (or any other router VM).
The WAN bridge (br1) is directly connected to the cable modem. The LAN bridge (br0) is used as a linux switch for other VMs to connect to the internet.
The cable modem has DHCP capablity and it cannot do “bridge” mode.
But I am not able to get the WAN port of PfSense to get DHCP, DNS or to ping 8.8.8.8 from the cable modem. Ubuntu VM on proxmox also cannot ping 8.8.8.8 when the hardware network is set to br0 or br1.
When I connect the cable modem to an external TP-LINK router and connect the external router’s LAN port to proxmox’s WAN port (br1), everything works.
The problem lie in Pfsense WAN interface cannot DHCP from cable modem directly. There is a routing problem on proxmox.
I watched several proxmox learn linux TV youtubes but I cannot get this to work.
I think many people want to use proxmox as a “router”, bypassing any external router. If you can help with this setup or any video on youtube that have instructions to do that. Thank you.
