I tried to set up a Nextcloud with Linode and your guide on Youtube (“The comlete guide to nextcloud”, or so).
Most of the commands worked and my nextcloud is running now. Since my Domain isn’t set up now, and it could need some hours for “activating it”, i wasn’t able to do one of the last command to set up encryption for my nextcloud. But this should work as soon as my domain does. So this shouldn’t be a problem. Even though, i can’t use my nextcloud at the moment, due to missing encryption with TLS.
But:
I had an error with the memcache setup in the following command:
xxx@nextcloud:~$ sudo php /var/www/mydomain.ch/occ db:add-missing-indices
An unhandled exception has been thrown:
OC\HintException: [0]: Memcache \OC\Memcache\APCu not available for local cache (Is the matching PHP module installed and enabled?)
So it looks like some php module isn’t installed or enabled. But i do not know which of the modules is needed for the memcache setup. So could you help me out with a hint, which module(s) i need to install and enable again, to be sure this command will work?
Ok. Pakage is intalled (both).
Will read the documantation later, perhaps i’ll find something helpful.
Short question:
I think this shouldn’t be a problem. But my domain isn’t active, since i’m waiting for the A-Record to be “online”. could this be the problem?
I seem to remember that I had the same error message when I first installed Nextcloud following Jay’s instructions, a week or so ago. I checked to make sure that php-acpu module was installed (it was). The error seemed to go away by itself, eventually, after a couple hours of further tinkering, possibly due to a system re-boot?
Anyway, Nextcloud has been running faultessly for me for a week now, with good performance.
