Hi, Everyone.
I hope you can help me with my problem, I have an ubuntu server 20.04. It is vmguest in xcp-ng. The root partition was originally 20 GB. Since it already used up most of the space I need to increase the capacity to 30 GB. I have done this using parted:
Model: Xen Virtual Block Device (xvd)
Disk /dev/xvda: 32.2GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 2097kB 1049kB bios_grub
2 2097kB 32.2GB 32.2GB
If I perform “fdisk -l” it sees that the size has increased
user1@graylog1:~$ sudo fdisk -l
Disk /dev/xvda: 30 GiB, 32212254720 bytes, 62914560 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: F0D97B47-EBC7-410D-88EF-D826038D110E
Device Start End Sectors Size Type
/dev/xvda1 2048 4095 2048 1M BIOS boot
/dev/xvda2 4096 62890625 62886530 30G Linux filesystem
but if I run df -h it is still showing 20 GB
user1@graylog1:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 1.9G 0 1.9G 0% /dev
tmpfs 391M 1.1M 390M 1% /run
/dev/xvda2 20G 18G 847M 96% /
Hope you can show me how to properly extend my partition to show up in df -h
