Moral of The Story: Read the damn release notes !!
=> K3S v1.21.3+k3s1
I just spent all afternoon calling K3S every name in the book besides a viable Kubernetes engine.
Here’s the story, without all the colorful metaphors.
Cluster Components
- pqdb - K3S PostgreSQL External Database
- k3s-lb - Nginx Stream Load Balancer (TCP and UDP)
- k3s-server{1,2} - server nodes (servers, non-pod targets)
- k3s-agent{1…5} - agent nodes (workers, pod-targets)
In older versions of K3S < 1.21.3, you didn’t have to specify K3S_TOKEN=123XYZ for adding additional server nodes, but you did for agents. Well that’s changed in 1.21.3+. Also, you MUST have both your database and load balancer up and running “before” joining your server nodes (should be obvious, but it’s not always). The Rancher Docs are far from clear on this minor detail
So the process goes something like this (if you want a fancy doc, I can write it up).
# On Server-1, execute the following
export K3S_DATASTORE_ENDPOINT='postgres://somebody:something@192.168.0.XX:5432/k3s'
sudo curl -sfL https://get.k3s.io | sh -s - server --node-taint CriticalAddonsOnly=true:NoExecute --tls-san 192.168.0.XX
# Important - get the K3S_TOKEN !!!
sudo cat /var/lib/rancher/k3s/server/node-token
12345ABCDE
Exit Server-1 and ssh in to Server-2
# On Server-2, execute the following
sudo curl -sfL https://get.k3s.io | K3S_TOKEN=12345ABCDE sh -s - server --node-taint CriticalAddonsOnly=true:NoExecute --tls-san 192.168.0.XX
Exit Server-2 and ssh back in to Server-1, then check node status
# Back on on Server-1, execute the following
radio@k3s-server1:~$ sudo k3s kubectl get nodes
[sudo] password for me:
NAME STATUS ROLES AGE VERSION
k3s-server1 Ready control-plane,master 11m v1.21.3+k3s1
k3s-server2 Ready control-plane,master 25s v1.21.3+k3s1
Additionally, when adding you’re k3s-agent(x) nodes, you will also need to use that same token, otherwise, you get join errors referencing token errors.
Anyway, I hope this helps prevent others from having the same frustration.
