I’m trying to use KVM to virtualize a two node Oracle RAC DB (for testing) on an Intel NUC, connected to WiFi using an Intel AX201 card. In the excellent book, Mastering Ubuntu Server 3rd edition, we have this example to create a bridge:
network:
ethernets:
enp0s3:
dhcp4: false
bridges:
br0:
interfaces: [enp0s3]
dhcp4: true
parameters:
stp: false
forward-delay: 0
This Intel NUC is running headless and connected only to WiFi, running Ubuntu Server 20.04.4 with the HWE kernel. So I tried editing /etc/netplan/00-installer-config-wifi.yaml:
network:
version: 2
wifis:
wlp0s20f3:
access-points:
Unifi:
password: **************
dhcp4: true bridges:
br0:
interfaces: [wlp0s20f3]
dhcp4: true
parameters:
stp: false
forward-delay: 0
followed by:
sudo netplan apply
But then I get disconnected from WiFi as it doesn’t get an IP. I have done some googling and it seems the problem is due to the AP (in my case a Unifi Dream Machine) rejecting the connection as it is not done via the WiFi card:
https://wiki.debian.org/BridgeNetworkConnections#Bridging_with_a_wireless_NIC
so it seems we must use ebtables.
Some other sources mention this is not possible to be achieved. While some sources mention it must be done using DNS forwarding.
So, how to achieve WiFi bridging?
Thanks
