i was told flatseals cant be used for gaming.
but, if you turn the game data into flatpaks then you can use the permissions of flatseals.
how do you create a flatpak? cause i am trying to install a game from a dvd. war of the ring.
im using arch linux.
im also trying to load the no dvd patch. that wont play. but, if you use a dvd. it play.
will flatpaks solve that issue?
