[Help] Is there a way to prevent the monitors from turning off on Pop!OS 21.04 when I lock my laptop
I’ve noticed that whenever I lock my laptop, immediately the external monitors are turned off. I usually use my laptop with the lid closed and always on power and I don’t need this. Is there a way to prevent this?
I tried this but it didn’t work.
gsettings set org.gnome.settings-daemon.plugins.power idle-dim false
It’s been a while since I’ve done this, but have a look at the options in logind.conf.
See Man Pages for more options : logind.conf
# cat /etc/systemd/logind.conf
# These options => to ignore
HandleLidSwitch=ignore
HandleLidSwitchDocked=ignore
# Save and exit the file
# then restart the service
sudo systemctl restart systemd-logind.service
It didn’t work. But thanks anyway.
I remember going through this, just not the exact steps. I’ll have to research it more. Problem is, I don’t have a laptop to test it on.
May want to look at the options for lock with
IdleAction=
IdleActionSec=
Edit: the other thing I recall having chronic issues with was hibernate, suspend, and wake. They are all related in that mix one way or another.
