Hi, Everyone.
I am in trying to learn Openldap and following a video tutorial by theurbanpenguin. In his tutorial he created a file called “configure.ldif” in this file he added the following:
dn: olcDatabase={2}hdb,cn=config
changetype: modify
replace: olcSuffix
olcSuffix: dc=example,dc=com
changetype: modify
replace: olcRootDN
olcRootDN: cn=Manager,dc=example,dc=com
changetype: modify
replace: olcRootPW
#Password is Password1 or add your own
olcRootPW: {SSHA}EJESqvRThIecvYYkIU1NXr8niuNvaotm
dn: cn=config
changetype: modify
replace: olcLogLevel
olcLogLevel: 0
dn: olcDatabase={1}monitor,cn=config
changetype: modify
replace: olcAccess
olcAccess: {0}to * by dn.base="gidNumber=0+uidNumber=0,cn=peercred,cn=external,cn=auth" read by dn.base="cn=Manager,dc=example,dc=com" read by * none
My problem with this is with the “olcRootPW” if I use the actual password in that area and then execute the command:
ldapmodify -Y EXTERNAL -H ldapi:/// -f config1.ldif
and then perform an ldapadd
ldapadd -x -W -D "cn=Manager,dc=example,dc=com" -f structure.ldif
It accepts the password that I enter but if I replace the value of “olcRootPW” with a hash that was generated by
slappasswd -s n0v1ru$123 -n > rootpwd
and ran
and
it does not accept the password that I enter although it is the same password.
If you need more info so you can help me make this work and help me understand what happen, please let me know so I can provide those information.
