Hi, we have got a video where the cloud init is presented. Everything ok, working with dhcp, but what in situation when we must setup static ip? Is this possible?
I can setup static ip but when i restart a server dhcp working again. Any ideas what to do?
I have never used cloud-init myself, but I believe the point of it is to have a single configuration for users, network and SSH keys that can be set up on multiple machines, so basically like a template that you don’t need to mess around with, like booting a new instance of the server and doing manual changes.
However, you will probably be able to modify cloud-init for static IP address once you boot onto one system. Give Techno Tim’s video a watch:
He’s using proxmox, which gives a nice GUI for cloud-init, but you can do it manually. However, the cloud-init file will always get generated by cloud-init automatically after every reboot, which is likely why you are seeing this issue.
All the answers telling you to directly edit
/etc/netplan/50-cloud-init.yamlare wrong since CloudInit is used and will generate that file. In Ubuntu 18.04.2 it is clearly written inside the file :$ cat /etc/netplan/50-cloud-init.yaml # This file is generated from information provided by # the datasource. Changes to it will not persist across an instance. # To disable cloud-init's network configuration capabilities, write a file # /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following: # network: {config: disabled} network: ethernets: eno1: dhcp4: true version: 2So you should not edit that file but the one under
/etc/cloud/cloud.cfg.d/if you still want to use CloudInit.
So you probably have to edit the disk containing the cloud-init image to get a static IP assigned. Someone in the same page said this:
If still using CloudInit, you need to do a
sudo cloud-init clean -rto get the change to take [effect.]
Unsure if that helps, I’m no cloud-init guru, I’d rather make a template with all I need, then clone it and just slightly modify it, like setting a new static IP and a new hostname, cloud-init be damned!
