Thank you for the pointers-
Performing a git clone was my first test as well. It performs ok, see here:
charles@UbuntuWS:~/Git-repos/ansible-desktop$ git clone charles@ubuntu-server:/nfs/ubuntu-server/git-repos/ansible/ansible-desktop.git
Cloning into 'ansible-desktop'...
remote: Enumerating objects: 6, done.
remote: Counting objects: 100% (6/6), done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 6 (delta 0), reused 0 (delta 0), pack-reused 0
Receiving objects: 100% (6/6), done.
Yeah I’m not certain on the ansible-pull SSH syntax but I’ve tried a few:
As you suggested above, no : after the remote server’s hostname
charles@UbuntuWS:~/Git-repos/ansible-desktop$ sudo ansible-pull charles@ubuntu-server/nfs/ubuntu-server/git-repos/ansible/ansible-desktop.git
with colon after server’s hostname:
charles@UbuntuWS:~/Git-repos/ansible-desktop$ sudo ansible-pull charles@ubuntu-server:/nfs/ubuntu-server/git-repos/ansible/ansible-desktop.git
With ssh:// prefix which I read is the proper syntax on a stackoverflow post, not sure the info is accurate, but I tried anyway. I also added the local domain to the end of the hostname
charles@UbuntuWS:~/Git-repos/ansible-desktop$ sudo ansible-pull ssh://charles@ubuntu-server.charles.home/nfs/ubuntu-server/git-repos/ansible/ansible-desktop.git
ssh:// prefix combined with your suggestion of no colon after remote server hostname
Each of the above commands result in the same output. Its long so I will only paste once:
charles@UbuntuWS:~/Git-repos/ansible-desktop$ sudo ansible-pull ssh://charles@ubuntu-server/nfs/ubuntu-server/git-repos/ansible/ansible-desktop.git
usage: ansible-pull [-h] [--version] [-v] [-k] [--private-key PRIVATE_KEY_FILE] [-u REMOTE_USER] [-c CONNECTION] [-T TIMEOUT] [--ssh-common-args SSH_COMMON_ARGS] [--sftp-extra-args SFTP_EXTRA_ARGS]
[--scp-extra-args SCP_EXTRA_ARGS] [--ssh-extra-args SSH_EXTRA_ARGS] [--vault-id VAULT_IDS] [--ask-vault-password | --vault-password-file VAULT_PASSWORD_FILES] [-e EXTRA_VARS] [-t TAGS]
[--skip-tags SKIP_TAGS] [-i INVENTORY] [--list-hosts] [-l SUBSET] [-M MODULE_PATH] [-K] [--purge] [-o] [-s SLEEP] [-f] [-d DEST] [-U URL] [--full] [-C CHECKOUT] [--accept-host-key]
[-m MODULE_NAME] [--verify-commit] [--clean] [--track-subs] [--check] [--diff]
[playbook.yml ...]
pulls playbooks from a VCS repo and executes them for the local host
positional arguments:
playbook.yml Playbook(s)
optional arguments:
--accept-host-key adds the hostkey for the repo url if not already added
--ask-vault-password, --ask-vault-pass
ask for vault password
--check don't make any changes; instead, try to predict some of the changes that may occur
--clean modified files in the working repository will be discarded
--diff when changing (small) files and templates, show the differences in those files; works great with --check
--full Do a full clone, instead of a shallow one.
--list-hosts outputs a list of matching hosts; does not execute anything else
--purge purge checkout after playbook run
only run plays and tasks whose tags do not match these values
--track-subs submodules will track the latest changes. This is equivalent to specifying the --remote flag to git submodule update
--vault-id VAULT_IDS the vault identity to use
--vault-password-file VAULT_PASSWORD_FILES, --vault-pass-file VAULT_PASSWORD_FILES
vault password file
--verify-commit verify GPG signature of checked out commit, if it fails abort running the playbook. This needs the corresponding VCS module to support such an operation
--version show program's version number, config file location, configured module search path, module location, executable location and exit
-C CHECKOUT, --checkout CHECKOUT
branch/tag/commit to checkout. Defaults to behavior of repository module.
-M MODULE_PATH, --module-path MODULE_PATH
prepend colon-separated path(s) to module library (default=~/.ansible/plugins/modules:/usr/share/ansible/plugins/modules)
-U URL, --url URL URL of the playbook repository
-d DEST, --directory DEST
directory to checkout repository to
-e EXTRA_VARS, --extra-vars EXTRA_VARS
set additional variables as key=value or YAML/JSON, if filename prepend with @
-f, --force run the playbook even if the repository could not be updated
-h, --help show this help message and exit
-i INVENTORY, --inventory INVENTORY, --inventory-file INVENTORY
specify inventory host path or comma separated host list. --inventory-file is deprecated
-l SUBSET, --limit SUBSET
further limit selected hosts to an additional pattern
-m MODULE_NAME, --module-name MODULE_NAME
Repository module name, which ansible will use to check out the repo. Choices are ('git', 'subversion', 'hg', 'bzr'). Default is git.
-o, --only-if-changed
only run the playbook if the repository has been updated
-s SLEEP, --sleep SLEEP
sleep for random interval (between 0 and n number of seconds) before starting. This is a useful way to disperse git requests
-t TAGS, --tags TAGS only run plays and tasks tagged with these values
-v, --verbose verbose mode (-vvv for more, -vvvv to enable connection debugging)
Connection Options:
control as whom and how to connect to hosts
--private-key PRIVATE_KEY_FILE, --key-file PRIVATE_KEY_FILE
use this file to authenticate the connection
specify extra arguments to pass to scp only (e.g. -l)
specify extra arguments to pass to sftp only (e.g. -f, -l)
specify common arguments to pass to sftp/scp/ssh (e.g. ProxyCommand)
specify extra arguments to pass to ssh only (e.g. -R)
-T TIMEOUT, --timeout TIMEOUT
override the connection timeout in seconds (default=10)
-c CONNECTION, --connection CONNECTION
connection type to use (default=smart)
-k, --ask-pass ask for connection password
-u REMOTE_USER, --user REMOTE_USER
connect as this user (default=None)
Privilege Escalation Options:
control how and which user you become as on target hosts
-K, --ask-become-pass
ask for privilege escalation password
ERROR! URL for repository not specified, use -h for help
Part of me is thinking of taking the easy way out and cloning my git repo up to github and using GitHub as the primary repo instead of a local server. Maybe I am overcomplicating but I just see zero need to involve GitHub when a local server should be fully sufficient for this use-case.
