The Homelab Show Episode 81: Building Lab Templates and Images
Originally published at: The Homelab Show Episode 81: Building Lab Templates and Images – Learn Linux TV
When building a new virtual or physical server, doing everything manually is a waste of time. With an image or template, you can have some of your recurring tasks already set up on the image - and then every instance you create from that template will have all of those tweaks already made. But how far should you go with this default setup? What are some of the caveats that you might run into? In this episode, Jay and Tom discuss creating server images/templates and the related shenanigans you may run into while doing so.
