Setting up a Raspberry Pi Kubernetes Cluster with Ubuntu 20.04
Originally published at: Setting up a Raspberry Pi Kubernetes Cluster with Ubuntu 20.04 – LearnLinuxTV
Kubernetes is a very powerful platform to scale your applications, and the Raspberry Pi is a low-cost computer with excellent power efficiency you can use to run tasks without breaking the bank. Canonical recently released Ubuntu 20.04, with full support for the Raspberry Pi. In this video, we take a look at how to create a Pi-powered Kubernetes cluster based on Ubuntu.
I am getting these errors:
rchapman8@ubuntu1-controller:~$ sudo kubeadm init --pod-network-cidr=10.244.0.0/16
[init] Using Kubernetes version: v1.22.3
[preflight] Running pre-flight checks
error execution phase preflight: [preflight] Some fatal errors occurred:
[ERROR Port-10259]: Port 10259 is in use
[ERROR Port-10257]: Port 10257 is in use
[ERROR Swap]: running with swap on is not supported. Please disable swap
[ERROR Port-10250]: Port 10250 is in use
[preflight] If you know what you are doing, you can make a check non-fatal with --ignore-preflight-errors=...
To see the stack trace of this error execute with --v=5 or higher
Any ideas?
