Enterprise Linux Security Episode 46 - Monitoring
Originally published at: Enterprise Linux Security Episode 46 – Monitoring – Learn Linux TV
If you’re in charge of maintaining servers and related equipment, what should you monitor? While monitoring is something that will grow and expand over time, Jay and Joao will give you some tips in this episode. Check out this episode for some tips on some of the baseline checks you should implement with your monitoring solution of choice.
