Deploying Ubuntu Instances with MAAS
Originally published at: https://www.learnlinux.tv/deploying-ubuntu-instances-with-maas/
MAAS (Metal as a Service) gives you the ability to provision physical and virtual servers via an easy to use web console. You can use MAAS to deploy Ubuntu with ease, and it even supports PXE boot in order to provide you with a full deployment solution. In this video, you’ll get an overview of…
I would love to try them out once I have the money (and the job first) to buy a couple of rack-mounted servers for a homelab. I might use that to try out OpenStack with up to 3 nodes. :slight_smile:
