Originally published at: Awesome Linux Tools – ncdu – LearnLinuxTV
Do you know where your most-used files and directories are? Sure, there’s more than a few commands you can run to find out, but ncdu is a great tool for this purpose. Using ncdu, you can scan your entire hard disk (or any mounted filesystem) and determine where your storage pain points are - and take action!
